Dead center fairing install.
I got most of the components I need to install thanks to the advice from GANN! I have some silly questions, do I need to use marine grade speaker wire? And what gauge should I use if I'm bridging the amp? Going to run 8 gauge wire for the amp with a Anderson quick disconnect. Also should I pull the tank and run the wires down the frame? Didn't know if heat would be an issue. Here's what I'm going to run.
I got most of the components I need to install thanks to the advice from GANN! I have some silly questions, do I need to use marine grade speaker wire? And what gauge should I use if I'm bridging the amp? Going to run 8 gauge wire for the amp with a Anderson quick disconnect. Also should I pull the tank and run the wires down the frame? Didn't know if heat would be an issue. Here's what I'm going to run.Attachment 497345
Yes, pull the tank and secure the power and ground wires. There should be other wires running along there also.
Place a 35amp fuse at the battery.
I have a friend that wants to upgrade her DC Fairing audio. If you could post some pics of your progress that would be great.
fenderzig
05-26-2020 08:56 PM
Bunker
Audio Systems
12-16-2015 06:39 PM
