I have a BT 2180 with BT 7.1's in the fairing and BT 6.5 in the lowers.
Should I wire them up in parallel or off their own channel???
what would be best sound??
Sorry I'm a stereo newbie. I just like great sound.
Should I wire them up in this parallel or off their own channel???
The 2180 is a 2 channel amp which has second set of outputs that are connected internally in the amp.
Wire the fairing to the main speaker output and the lowers to the second set of outputs.
Don't use a heavy gauge speaker wire as you will have a difficult time getting the wire to seat in the connector on the amp.
Learn sumpin new everyday. I didn't realize the BT 2180 had those. Actually I did I just forgot.
