Phone isn't pairing
John -
Go to the setting app on your Iphone and clear all connections under "My devices" Basically what you are doing is starting over the "Pairing" process".
Make sure the phone is 1-2 feet from the radio.
Press the "Call" button on the Sony.
Rotate the big **** to the right until it says "Pairing"
The phone will only pair if the little BT symbol is flashing.
At this point your phone should be working to connect. When it connects you should see it on your phone under "My devices"
It should say "Connected"
If it doesn't. repeat the process. Sometimes it takes two or three times before it connects. The screen on the Sony should say "BTA" if successfully connected.
Hope this helps bro!
John -
You must have the IPhone 6 or 6+? I think it's in that model of phone because I was having that same problem off and on until I got the IPhone 7. Now the darn thing connects automatically as soon as I turn the bike on. I think it's the phone John. It should stay connected after you shut down the bike!!
musclehd
07-22-2018 06:41 PM
