Using the TWK AND LOVING IT!!
I'm ready to take the next step but looking for some info with the dsp's.
Incorporating a DSP into a system using a stock Rushmore HU does it have 2 settings to use for the on and off bin files?
Or will it compensate for the bin file changes when running or in aux position?
I have done some research but al the answers I found were clear as mud.
Can some one full the void in my head with some info?
Thanks
Thanks
Thanks
Thanks
After seeing how little space that takes up on a tourpack I don't know why more folks won't put some amps in their packs. It opens up so many possibilities. I'll have some more details on these TwK's when I get back home next week. Hopefully a thread review with pics and software.
T is the 2017 going to be ready for Daytona? We might make a few slight changes when I get home next week and have acces to some items I can send u. Would love for that beast to be part of our line up in Daytona.
Thanks
Thanks
There's no aux position or on to worry about. Simply put, when the head unit is playing the DSP is doing what it was programmed to do and that play music the way you set it up.
Way simpler than it seems. As haze said there is a learning curve BUT there is a simple way to set it up and use the regular eq until you learn a parametric eq.
You can download the software from JL and play with it. It has a simulation mode for doing just that.
It's when you really get into the full blown tweaking of the TWK that it's a learning process.
These DSP units are amazing, as will be the ones forthcoming.
If your wanting an easier DSP that's a self contained unit and with external eq control, look at the audiocontrol DSP-61. I've personally installed these, per recommendation, and it's all in all a great unit. Takes speaker level inputs directly. The only issue is size, wide but flat. Works fine in tourpacks
Can't wait to get a hold of the arc. I've been testing an audio control that is a new 2017 model yet to hit the market. It's phenomenal but too big for sled use.
Received 70,431 Likes
