Will a DSP be a benefit to my system question and answer thread
Pioneer head unit
jl600.6 , aw6.5 ,mmatts
jl 400.4 JL 8.8 ,pioneer pros
Would like to go back to my 6.5 Glade did not sell it thought someday Harley would fix problem
Also what do you think it would do for current setup Who would be willing to help set this thing up even if it cost me ?
T already said and you know how yours will work out. No brainer here. I think you need a DM-810 though. Good collaboration with BAL here.
More than anything, I hoping that the DSP will fix the inept Boom 6.5 regardless of how complex the setups are. If so, it then becomes a matter of what value folks will place on such EQ /DSP capabilities.
Will a DSP be valuable enuff to keep even average joe from dropping big $$$ on a replacement HU w shixxy functionality and an external GPS?
T.
T.
T.
T.
I removed the speakers and amp from my '16 FLTRUSE and added Hertz MPX165.3 (front) and Kicker 65CS (rear) along with a JL Audio 280/4, BT355. The BT355 has been removed and replaced with an Arc Audio PSM DSP. PSM was added to delay amp turn on, I was getting some ugly noise when powering on. Did I need the PSM outside of the amp noise issue ?
