Will a DSP be a benefit to my system question and answer thread
JL xd400/4v2 to DD aw6.5 with at at28's tweets in fairing. Bridged feeding roughly 200 per.
JL mx280/4 bridged roughly 160( if memory serves me correct) to focal krc 165 (original models) in tourpack.
Custom wire harness from HU to 2 Navone line levelers then into TWK 88 DSP.
6.5 HU
This is a 4 speaker system and was going to be a 6 speaker system but wife vetoed subs in bags since I'm going full out on my 2017 custom build.
Any thoughts on it and the DSP setup? There are many others that want a 4 speaker setup with DSP to eliminate the "limitations" of the BT LL with the 6.5 HU.
6.5 HU
purple and black wire that leads into a plastic plug. Your dealer will happily sell you a splitter for a few bucks and you should plug the DSP switched 12V into (purple) That would be the RED wire from the DSP going to the Accessory power.
The reason I think you're getting a bad noise is the BLUE wire from the DSP needs to connect to the switched 12V on your amp(s). You're powering the DSP and then letting the DSP switch your amps on, you should not have your blue amp wire running to the same splice as your DSP red wire. That's a no no. If you've got it wired correctly, disregard.
6.5 HU
6.5 HU
Chris maybe I am misunderstanding the post made about the turn on noise but sounded like the dsp was purchased to give a turn on delay that could be done using the mentioned harness vs using cig lighter. Then for that setup the dsp would not be very much of a need as the build is simple enough the tuning will yield minimal gains
Sorry guys for being unclear, I was getting the noise thru the speakers before I purchased the DSP. I had the amp remote turn on wired to the cigarette lighter and it powered on before the radio so I purchased the PSM (mistake no.1) I also thought it could defeat the frequency loss by the Harley Boom 6.5 when the engine is running. (mistake no.2)
Definitely some communication breakdown here. The DSP will do the job, but just was not or is not needed for the original issue. IT will correct the Boom units signal but in this small build a LL would have been fine. No mistakes here, just a little research could have saved a few bucks. You got the unit, assume it is installed and doing it's part. Enjoy it and ride on.
HD MOTORCYCLE APPLICATION TECHNICAL BULLETIN If you ae planning on using the PSM on any 2014+ HD Motorcycle please note that the Factory HD radio has crossovers built into the factory HD radio which will limit the frequency response from your factory source below 100Hz. Much like any DSP or amplifier on the market the PSM can only reproduce and correct signals that are provided to it. As such the PSM cannot create specific frequencies and can only process frequencies of signal that are being provided to it from your source.
