Keep My ARC Mini Amp?
Old 06-05-2011, 06:17 AM
Geezr Glidr's Avatar
Geezr Glidr
Geezr Glidr is offline
Default Keep My ARC Mini Amp?
Getting a new 103 LTD Ultra. Will do a speaker upgrade (J&M Rokker 7.25s? Don't know what to get.) & just wondering if I need a bigger amp then the ARC Mini 125 that I already own. Not sure yet if I need, or will do, an upgrade on the rear speakers. I probably will, knowin' me!
Old 06-05-2011, 01:24 PM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
Geezer ,,,,,
for the best sound all the way around for your new LTD, go here: http://www.jmcorp.com/SeeProducts.asp?PF=45 ,,,, and get the J&M ROKKER speaker upgrade for your fairing position, also the rear position, and the J&M 500w 4-channel amplifier ,,,,
if you would like to look over the install manuals for these three items, shoot me a private email ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old 06-06-2011, 08:58 AM
Geezr Glidr
Thanks John. I'm having a struggle with a $700 amp right now, since I already own that ARC Mini. Think the mini will help? I'll probably do the Rokker speakers --- front & back.
Old 06-06-2011, 09:31 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
I doubt you "need" a bigger amp than the Arc; it's 125W X 2 channels @ 2 ohms and 70W per channel at 4 ohms.
Your real choice will be whether to get a 4-channel amp, or, perhaps, another Arc mini for the tour pak speakers mouted in/under the tour pak.
In addition to the J&M 500W 4-channel amp, the Rockford Fosgate 300W, 4-channel amp is due in a few weeks. It's a 4 ohm impedance amp so the Rokkers would not be compatible with that amp.
A good friend has the HD 160W, 4-channel amp used on the CVO Ultras on his '06 EG Ultra and is very pleased with it. With the harness, these amps show up often for about $250-$300, ususally from CVO owners swapping out those amps for more powerful aftermarket units. With the harness, it would be a plug and play installation.
Good luck with your research and new bike.
Carl
Old 06-06-2011, 10:08 PM
Geezr Glidr
Thanks Carl. I think I'll keep the ARC Mini, and just not power the rear pods for now --- see how they do.
Bigswann
Audio Systems
06-14-2017 08:02 PM
Rickpay1
Audio Systems
09-13-2015 01:17 PM
dynacop25
Audio Systems
05-13-2013 02:19 PM
ultra5516
09-29-2012 07:09 PM
bcc007
Audio Systems
10-11-2011 03:37 PM
Quick Reply: Keep My ARC Mini Amp?
