New Bracket to mount HD modules under the HK radio
For those looking to add amps above the HK radio, but have CB, iPod, XM, or NAV modules mounted above, member Scott Ezzell (ezzell141@comcast.net) has a new bracket to easily, and securely, mount the module(s) under the HK radio.
The bracket is nicely finished in a black powdercoat, and uses the four screws that secure the radio to the vertical brackets. You remove the forward two screws and loosen the two rear screws so the bracket can slide in (the rearward two screw locations use slots to capture those screws).
After sliding the bracket in, you simply reinstall the forward two screws and tighten the rearward two screws. Then install the module(s) (in my case the CB and Ipod modules) and secure with a short screw and nut.
So, if your're looking to add an amp above the HK radio, but have HD module(s) installed, Scott has a great bracket to address the issue.
I'll post some pictures soon; or, simply email Scott and he can fill you in.
Carl
PS: Scott also has a new bracket for installing the amp above the HK radio if you don't want to put the amp directly on top of the HK radio. For my application, I couldn't use that bracket, but I've seen the bracket and it's a nice piece.
PPS: I'm not affiliated with Scott in any way; just passing along information on a new product just as many others have done in the past.
Carl
You may find some helpful information in this thread:
https://www.hdforums.com/forum/touri...head-unit.html
Carl
Carl
I have a 2012 FLHTK with the factory CB. Will I need this bracket if I want to install the HD Boom! amplifier?
http://www.harley-davidson.com/gma/g...5&default=none
Carl
