Boom Speakers with poly fill
Old 03-27-2014, 08:37 PM
dugan's Avatar
dugan
dugan is offline
Default Boom Speakers with poly fill
Just installed Boom 5.25" speakers and added poly fill around them. Do the Booms need the fill or take it out? They are not wrapped heavily with it, just some I had laying around and just stuffed it in there. Advice?
Old 03-28-2014, 03:08 AM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
They need all the help you can give them....
Old 03-28-2014, 06:20 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
They ALL need polyfil.
Old 03-28-2014, 07:15 AM
dugan's Avatar
dugan
dugan is offline
Thanks the tip guys. I'm just not sure if what I'm using is sufficient. Heck, not even 100% sure it's polyfil because it was just laying around the house, I didn't go buy it. Think it came as some sort of packing from something. But the point is, you're suggesting the Boom's need to be wrapped?
Old 03-28-2014, 07:31 AM
UltraNutZ's Avatar
UltraNutZ
looks like polyfil to me. the idea size for speakers of the 5.25" to the 7.1" range is
3 sheets of the thin stuff from Walmart craft section in a 15x15" square wrapped around each speaker in the fairing.
lowers and rear pods a single thin layer lining the pod, don't wrap these speakers
Old 04-01-2014, 09:23 PM
qcarson's Avatar
qcarson
qcarson is offline
Dugan, how did you secure the polyfil to the speakers? I believe I have the wrong polyfil. I bought the quilt batting stuff. I am more of a visual learner so pics would be nice.
Old 04-02-2014, 06:56 AM
zeke383's Avatar
zeke383
zeke383 is offline
If you bought 100% polyester that is about 3/8" thick, then you bought the right stuff.
Old 04-02-2014, 07:53 AM
dugan's Avatar
dugan
dugan is offline
I just stuffed it in around the crevasses where it would fit. Just temporary to see if it works. I've heard of zip tie around the round part of the speaker also. When I take the fairing off again I will secure the fil better and probably use actual layers of thin Polyfil in there.
Old 04-02-2014, 04:09 PM
qcarson's Avatar
qcarson
qcarson is offline
Zeke383, you are correct. When I opened it up I saw that it was thinner than I expected. I am getting ready to go try and attach it now. Thanks for the reply though.
Old 04-02-2014, 04:11 PM
qcarson's Avatar
qcarson
qcarson is offline
Can you hear an actual difference? I have lower speakers also so I am about to wrap them all.
Quick Reply: Boom Speakers with poly fill
