Hearing distortion free music over 80 mph possible?
I recently installed a full stereo (sony DSX S310btx, BT 7.1, BT 2180 fairing spks only). I can hear the stereo very clear up to about 65-70 mph and then I can't turn it up any higher without reaching distortion. The setting is at 30, for those who have the 310btx.
My question is, it is possible to upgrade a stereo so it can be heard clearly at 80 +mph?
I am not interested in a bumping system at a stop light, or a parking lot. Only highway travelling and higher speeds. If you were able to accomplish this can you list what made the biggest impact. ie speakers in lowers, another set in the fairing, tweeters, etc
I talked with biketronics tech support and I was told that a setting of 30 was probably my limit for the type of music I listen too.
If your model has the low pass filter, set it to 70mhz or maybe even a little higher depending on the type of music you listen to. That made a big difference in my Sony model as I listen to a lot of R&B. If I'm parked, like I was at bike night tonight, I drop it down to 50hz and let my rear Pioneers do most of the work for the bass. You have a great setup with the BT.
Op I'm in the same boat, I run the stock hu ( which sucks) and I run a ss4.520d with a set of bt 7.1 I also come to the conclusion the the sound I'm wAnting my bike to have is not realistic of just the two speakers alone regardless of the quality of the speakers. I'm pulling the trigger on a set of rear speaker lids at the moment although I beleive a set of speakers in a set of lower fairing may achieve better results. Others may be able to shed more light on that, I ride a street glide and am just not ready to commit to having lowers on my bike.
I started out with stock HU, RF 300x2, and polk mm651. Initially didn't sound right until after 2 days riding. I did many amp/HU adjustments until I decided to TURN OFF AVC. Made a huge difference in clarity and could easily be piercing at 85 mph. (gain about 6, HP, Freq ~125, bass 0, treble 0)
Just yesterday, replaced fairing with biketronics 7.1 and will be putting the mm651 in lowers next week. The 7.1 sounds good in garage, but sound is not as good at 85 (gain about 5 1/4, AP, bass -1, treble +3). Just like you, upset they don't sound better at that speed. The sound is just not as "tight " as the polks were.
Plan to try HP with Freq about 80 to see if there is a difference. I'm sure once I get the polks in the lowers on a second amp I'll be good, but would love to hear others opinions on tuning the 7.1's.
Definitely try turning AVC off though. That with the polks on those settings made a big difference in mine at 85. That's my experience.
