Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Here I come Turbo
Old 01-12-2016, 09:11 PM
TurboChris's Avatar
TurboChris
TurboChris is offline
Thanks for the replys guys!
Old 01-14-2016, 04:21 PM
Boost's Avatar
Boost
Boost is offline
Originally Posted by Deadstroke
Well I picked Aerocharger because of the following
- Would rather use a Procharger on a Welded Crank.
I hope this doesent mean that you are not planning to weld the crank. Welding or plugin that crank is crucial on any high power application.
Old 01-14-2016, 04:24 PM
zer0t's Avatar
zer0t
zer0t is offline
You can put pretty light boost on the aerocharger using the various springs and shims. I don't know what the OP plans on running but I think you can go as light as 5-7 lbs. The Aerocharger guys are on the forum and can answer that.
Post up some pics when you get it done. Good luck.
Old 01-20-2016, 08:50 AM
Deadstroke's Avatar
Deadstroke
Deadstroke is offline
5 pounds is the lowest they offer I will be doing 7.5 with a inter-cooled.. You can go to 8 without a welded crank. I have seen them as high as 10 but don't think i would push that..
Going with a small side dump this is going to get interesting
Old 01-21-2016, 06:38 AM
GraemeR's Avatar
GraemeR
GraemeR is offline
I have gone up to 20 (by mistake) and the crank survived, but I'd not recommend it full time.
You should be fine running under 10 without welding the crank, although i would not recommend above 8 without an intercooler.
Old 01-25-2016, 09:27 PM
BadBagger08's Avatar
BadBagger08
BadBagger08 is offline
Only thing that will guarantee your crank from slipping is not starting your bike. If the crank is going to slip a weld isn't going to stop it, its only for peace of mind.
Crank didn't slip, but now the warranty is void because it was welded.
Old 01-28-2016, 03:41 PM
Deadstroke's Avatar
Deadstroke
Well it is here, lets see how bad I can mess this install up...
Old 03-02-2016, 05:00 PM
Deadstroke's Avatar
Deadstroke
It is on
Old 03-03-2016, 08:20 AM
PFWiz's Avatar
PFWiz
PFWiz is offline
Ohh, turbo ****, me likey!
Give us more!
It is on
Old 03-03-2016, 08:43 AM
Deadstroke's Avatar
Deadstroke
Quick Reply: Here I come Turbo
