Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Turbo Vs. Super-Charger
Old 01-18-2010, 09:58 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
DRAGO'S BIKE WORKS is offline
Former Sponsor
Default Turbo Vs. Super-Charger
Get ready to read........
It's one of the most common questions we are asked - the answer to which is almost impossible to find
"What is better - a supercharger or a turbo?"
We only wish the answer were that simple, but unfortunately it is not. The simple answer is:
"It depends."
But don't worry, we'll go into more depth than that here. Both superchargers and turbos have distinct advantages and disadvantages. Selecting the right kind of forced induction for your vehicle will depend upon your particular vehicle, your driving habits, your power preferences, and your needs.
Clearing Up Confusion
According to Merriam-Webster's dictionary, a supercharger is defined as:
"a device (as a blower or compressor) for pressurizing the cabin of an airplane or for increasing the volume air charge of an internal combustion engine over that which would normally be drawn in through the pumping action of the pistons".
A turbocharger is defined as:
"a centrifugal blower driven by exhaust gas turbines and used to supercharge an engine".
According to Webster's, a turbocharger is included in the definition for superchargers - it is in fact a very specific type of supercharger - one that is driven by exhaust gasses. Other superchargers that do not fall into this category - the kind that we are all used to hearing about - are normally driven directly from the engine's crankshaft via a crank pulley. So in reality, it is not fair to compare all superchargers to turbochargers, because all turbochargers are also superchargers. For the purpose of this discussion, however, a supercharger will be considered all superchargers that are are not driven directly by the engine, while turbochargers will be considered all superchargers that are driven by engine exhaust gasses.
Similarities
Both superchargers and turbochargers are forced induction systems and thus have the same objective - to compress air and force more air molecules into the engine's combustion chambers than would normally be allowed at atmospheric pressure here on Earth (14.7 psi at sea level). The benefit of forcing more air molecules into the combustion chambers is that it allows your engine to burn more fuel per power stroke. With an internal combustion engine, burning more fuel means that you convert more fuel into energy and power. For this reason, supercharged and turbocharged engines normally produce 40% to 100%+ more power (depending on the amount of boost - check out our horespower calculator) than normally aspirated engines.
How They Work
A supercharger is mounted to the engine and is driven by a pulley that is inline with the crank (or accessory) belt. Air is drawn into the supercharger and compressed by either an impeller (centrifugal-style supercharger), twin rotating screws (screw-type supercharger), or counter-rotating rotors (roots-type supercharger). The air is then discharged into the engine's intake. Faster crank speed (more engine rpm) spins the supercharger faster and allows the supercharger to produce more boost (normally 6 to 9 psi for a street vehicle). Typical peak operating speeds for a supercharger are around 15,000 rpm (screw-type and roots style superchargers) and 40,000 rpm (centrifugal-style superchargers).
A turbocharger operates in much the same way as a centrifugal (internal impeller) supercharger, except it is not driven by pulleys and belts attached to the engine's crank. A turbo is instead driven by exhaust gasses that have been expelled by the engine and are travelling through the exhaust manifold. The exhaust gas flows through one half of the turbocharger's turbine, which drives the impeller that compresses the air. Typical operating speeds of a turbocharger are between 75,000 and 150,000 rpm.
Head to Head Comparison
Now it's time to evaluate the turbocharger versus the supercharger according to several important factors.
Cost
The cost of supercharger and a turbocharger systems for the same engine are approximately the same, so cost is generally not a factor.
Lag
This is perhaps the biggest advantage that the supercharger enjoys over the tubo. Because a turbocharger is driven by exhaust gasses, the turbocharger's turbine must first spool up before it even begins to turn the compressor's impeller. This results in lag time which is the time needed for the turbine to reach its full throttle from an intermediate rotational speed state. During this lag time, the turbocharger is creating little to no boost, which means little to no power gains during this time. Smaller turbos spool up quicker, which eliminates some of this lag. Turbochargers thus utilize a wastegate, which allows the use of a smaller turbocharger to reduce lag while preventing it from spinning too quickly at high engine speeds. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses boost pressure, and if it gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down..
A Supercharger, on the other hand, is connected directly to the crank, so there is no "lag". Superchargers are able to produce boost at a very low rpm, especially screw-type and roots type blowers.
Efficiency
This is the turbo's biggest advantage. The turbocharger is generally more economical to operate as it as it is driven primarily by potential energy in the exhaust gasses that would otherwise be lost out the exhaust, whereas a supercharger draws power from the crank, which can be used to turn the wheels. The turbocharger's impeller is also powered only under boost conditions, so there is less parasitic drag while the impeller is not spinning. The turbocharger, however, is not free of inefficiency as it does create additional exhaust backpressure and exhaust flow interruption.
Heat
Because the turbocharger is mounted to the exhaust manifold (which is very hot), turbocharger boost is subject to additional heating via the turbo's hot casing. Because hot air expands (the opposite goal of a turbo or supercharger), an intercooler becomes necessary on almost all turbocharged applications to cool the air charge before it is released into the engine. This increases the complexity of the installation. A centrifugal supercharger on the other hand creates a cooler air discharge, so an intercooler is often not necessary at boost levels below 10psi. That said, some superchargers (especially roots-type superchargers) create hotter discharge temperatures, which also make an intecooler necessary even on fairly low-boost applications.
Surge
Because a turbocharger first spools up before the boost is delivered to the engine, there is a surge of power that is delivered immediately when the wastegate opens (around 3000 rpm). This surge can be damaging to the engine and drivetrain, and can make the vehicle difficult to drive or lose traction.
Back Pressure
Because the supercharger eliminates the need to deal with the exhaust gas interruption created by inserting a turbocharger turbine into the exhaust flow, the supercharger creates no additional exhaust backpressure. The amount of power that is lost by a turbo's turbine reduces it's overall efficiency.
Noise
The turbocharger is generally quiter than the supercharger. Because the turbo's turbine is in the exhaust, the turbo can substantially reduce exhaust noise, making the engine run quieter. Some centrifugal superchargers are known to be noisy and whistley which, annoys some drivers (we, however, love it!)
Reliability
In general, superchargers enjoy a substantial reliability advantage over the turbocharger. When a a turbo is shut off (i.e. when the engine is turned off), residual oil inside the turbo's bearings can be baked by stored engine heat. This, combined with the turbo's extremely high rpms (up to 150,000rpm) can cause problems with the turbo's internal bearings and can shorten the life of the turbocharger. In addition, many turbos require aftermarket exhaust manifolds, which are often far less reliable than stock manifolds.
Ease of Installation
Superchargers are substantially easier to install than a turbos because they have far fewer components and simpler devices. Turbos are complex and require manifold and exhaust modifications, intercoolers, extra oil lines, etc. - most of which is not needed with most superchargers. A novice home mechanic can easily install most supercharger systems, while a turbo installation should be left to a turbo expert.
Maximum Power Output
Turbos are known for their unique ability to spin to incredibly high rpms and make outrages peak boost figures (25psi+). While operating a turbocharger at very high levels of boost requires major modifications to the rest of the engine, the turbo is capable of producing more peak power than superchargers.
Tunability
Turbochargers, because they are so complex and rely on exhaust pressure, are notoriously difficult to tune. Superchargers, on the other hand, require few fuel and ignition upgrades and normally require little or no engine tuning.
While the supercharger is generally considered to be a better method of forced induction for most street and race vehicles, the turbo will always have its place in a more specialized market. Superchargers generally provide a much broader powerband that most drivers are looking for with no "turbo lag". In addition, they are much easier to install and tune, making them more practical for a home or novice mechanic.
Old 01-18-2010, 02:55 PM
legacycycles's Avatar
legacycycles
legacycycles is offline
Oops
Ill help to try and simplfy the answer...In an application where the engine has got alot of rpm's(V-Rod)Turbo all the way....For aircooled vtwin,supercharge her.
Old 01-20-2010, 10:54 AM
donnie06hd's Avatar
donnie06hd
donnie06hd is offline
The weather down here in florida is great today. I rode my ati pro-charged bike for a couple of hours this morning. Damn it runs good!!!
Old 01-20-2010, 04:36 PM
DRAGO'S BIKE WORKS
Former Sponsor
Don,
I am happy to hear that everything is great. It makes me feel good when a customer is happy......
Old 01-20-2010, 07:05 PM
Night_Train's Avatar
Night_Train
Night_Train is offline
quick note:
Screw (Lysholm)/Roots (Eaton) superchargers are positive displacement.
Example: you have a 2.3 liter supercharger it delivers 2.3 liters per revolution at any RPM, regulated by a bypass.
Turbo/Pro Chargers are not a positive displacement supercharger and rely on higher RPM's to make peak power.
Both work quite well in the right application as already stated.
Old 01-22-2010, 06:01 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
From the time when I didn't know anything, Last week really, I remember wondering about the difference between positive displacement and the other kind which is really a type of fan. Uses velocity, in a way, to build pressure.
For guys just starting out, wern't we all, positive displacement means the device takes a particular piece of, in this case air, and moves it from one side of itself to the other. Low side to high side.
The other kind of device blows the hell out if it till pressure builds.
I would think a positive displacement, for a motorcycle, would be much simpler to manage. Particularly for a Harley on the street. (Cause it's ---BOOM--- right there.)
Old 01-22-2010, 07:38 PM
DRAGO'S BIKE WORKS
Former Sponsor
The charts are showing the different types of power adders. To answer your questions.
Old 01-25-2010, 04:26 PM
Old Gunny's Avatar
Old Gunny
You are absolutely right. I wandered off.
I forgot the procharger and the method of driving it. Which was what we were talking about. Hell to get old.
Old 01-25-2010, 04:59 PM
DRAGO'S BIKE WORKS
Former Sponsor
No prob. I am 37 and still forget LOL LOL....
Old 01-28-2010, 09:16 AM
Old Gunny's Avatar
Old Gunny
Just to think about how proven these things are.
The first time I ever saw one of these I was about 14. The big brother of my good friend bought a 1957 Thunderbird. Had a 312 Y block and a factory "Paxon Supercharger". Power Blue convertible. 4 speed. I think it came standard with a good looking blond.
Quick Reply: Turbo Vs. Super-Charger
