Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Why is my Pilot so High?
Old 09-29-2014, 04:22 PM
Musicman33's Avatar
Musicman33
Musicman33 is offline
Stage III
Default Why is my Pilot so High?
Hey guys, new to the forum and thanks in advance for your input! So here's the deal:
Just bought a 1992 Sportster 1200. Screamin Eagle Air Kit, HD exhaust slip ons. I clean the carb and this is what i find. 68 Slow Jet/ 160 Main. It was running rich to say the least, had the mix screw backed out 3 full turns. If you pulled the choke out it would kill the engine right away. So I switched the slow to a 45. Now I had to put mix screw all the way in and have the choke on to even have it run for a few seconds before it cuts out. My guess is I'll need to split the difference to maybe 58 or so for slow jet. My main question is this, most guys i've read with similar mod's are running a jet in the high 40's at most. Is there something I need to check that would cause my bike to need a slow jet in the high 50's? It seems excessive to me. Thought I'd check before purchasing more jet sizes. Thanks.
Old 09-30-2014, 09:20 AM
Musicman33's Avatar
Musicman33
Stage III
96 views and not a single reply. Guess i joined the wrong forum.
Old 09-30-2014, 09:29 AM
seehogs's Avatar
seehogs
seehogs is offline
It' still early. Try 45/48 pilot with 175/180 main.
You can use washers to space the needle up a couple mm's.
Old 09-30-2014, 09:56 AM
O-Town D's Avatar
O-Town D
O-Town D is offline
Pretty much what I used on my '90 FXR with S&S A/C and Thunderheader - #45 slow and #180 main with two washers under the jet needle. I recommend you check the carb-to-manifold and manifold-to-head seals - if those are sucking air your carb/motor will never run right. Hope you get it worked out.
Old 09-30-2014, 12:09 PM
Musicman33's Avatar
Musicman33
Stage III
thanks for the feedback guys. I will try shimming the needle.
Old 01-11-2015, 02:40 AM
mad jak's Avatar
mad jak
mad jak is offline
intake gasket leaks u would need a bigger jet to make bike run they only cast bout 12dlrs for 3 new gaskets now you got a smaller jet there is not enough fuel and to much air to make bike run
Old 01-12-2015, 04:07 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,743 Likes on 928 Posts
I agree with the previous posts. Replace the intake manifold seals. That is your problem. YD
05sportie
02-25-2019 04:23 PM
GOGOBECK
EVO
27
09-29-2018 06:19 PM
Sportster330
04-15-2016 06:07 AM
gilmour68
08-19-2012 04:47 PM
jaws134
05-23-2006 12:39 PM
Quick Reply: Why is my Pilot so High?
