Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Mikuni HSR42 TC95" Jetting
Old 02-21-2016, 12:35 PM
hutch08's Avatar
hutch08
hutch08 is offline
Default Mikuni HSR42 TC95" Jetting
Looking for some baseline jetting suggestions for my Dyna. I just pulled the stock CV40 off and replaced it with a Mikuni HSR42 carb.
Here's my engine specs:
95" big bore with Wiesco flat top pistons, measures around 10.2:1
Underground Performance 78cc heads, shaved, step milled, high velocity ports
1.9" intake valves, high lift springs
SE adjustable rods
Feuling lifters
S&S 585G easy start cams
S&S stealth intake
Bassani short road rage 2-1 exhaust
Crane Fireball Hi-4tc ignition
Elevation is around 2000' , plans are to eventually get it dyno tuned but I'd like to have some baseline jetting in place so I can at least ride it.
Right now the carb is all stock, 160 main, 25 pilot, 70 acc pump jet.
What do you recommend for a baseline?
Thanks!
Old 02-24-2016, 05:59 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
That should certainly allow you to ride it, as that jetting combo covers a broad spectrum.
You may see a 165 main after all is said and done.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
ButtMan1000
Exhaust System Topics
11-04-2012 10:34 AM
BLACK LABEL
03-02-2012 07:06 AM
justanotherjim
08-29-2010 05:30 AM
bjornsson
08-23-2006 06:46 PM
Crankyjay
04-05-2006 08:59 AM
Quick Reply: Mikuni HSR42 TC95" Jetting
