Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
midrange performance problem
Old 08-14-2011, 01:10 PM
bigcountry4160's Avatar
bigcountry4160
bigcountry4160 is offline
Stage III
Default midrange performance problem
Ok, I am working on an 86 sportster 883 that has been bored and stroked, straight pipes, keihen buterfly carb, 155 main jet, 66 pilot jet. The problem I'm having is that at about 1/3 throtle it starts cuting out, back fire through the carb, uses lots of gas, also fuel spray out of the carb when i'm running during the back fire. It always has been very rich but recently its gotten to the point that mid range is out of the question. ive been through the carb twice, no change. any advice would be awesome. my next move will be cylinder leak down, compression test, I'll post results soon. HELP!!!
Old 04-15-2014, 02:53 PM
IronHeadDrew's Avatar
IronHeadDrew
IronHeadDrew is offline
I have thesame problem...find your solution?
Old 04-15-2014, 08:43 PM
amasoniii's Avatar
amasoniii
amasoniii is offline
Just realized this was an old thread. So if you are having the problem the original poster had, drop the bowl and make sure there is a rubber plug over the idle jet. If not, you need one. Just get a rebuild kit and it will have one.
Old 04-15-2014, 09:04 PM
amasoniii's Avatar
amasoniii
Most people will tell you to get rid of the butterfly keihin, but i won't. Mine starts and runs better than most factory CV's i've seen.
A couple of tips i got from an old easy rider article to get it tuned are 1) install a screw into the hole of the tab that operates the accelerator pump so you can adjust how much it works (especially needed if you install an andrews accelerator pump and drill the extra feed hole), 2) make sure the rod for the accelerator pump is flush with the carb body when the throttle is completly closed.
An additional thing i did on mine is increase the spring pressure on the choke butterfly to make sure it doesn't vibrate when open. You just have to loop the spring around one more time. Finally, just make sure you have no carb mounting or intake leaks.
Your symptoms point to that plug being left out though.
Old 04-15-2014, 09:08 PM
amasoniii's Avatar
amasoniii
Oh, left one tip out, make sure the jet for the accelerator pump shoots the gas directly into the center of the butterfly or manifold. You can turn it with a wrench when you have the bowl off. Usually it comes from the factory shooting more toward the rear cylinder.
Old 04-16-2014, 05:47 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
With 1 3/4" straight pipes on an EVO XL, tremendous reversion is occuring.
3" from the end on the pipe, drill a clearence hole for a 1 1/2" long, 5/16" bolt, and simply stack 3-4 3/8" nuts on it, then nut it.
You will IMMEDIATELY notice a large torque increase, and NOW, tuning can begin, now that the pipe is attempting to work.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
1/2crazedbikr
EVO
15
12-10-2022 03:59 PM
CZshooter
Carburetor Related
08-05-2015 09:15 PM
skinman13
06-30-2014 02:43 PM
strantor
Exhaust System Topics
06-09-2009 10:26 PM
solitaryman54
Ironhead
04-23-2007 01:18 AM
Quick Reply: midrange performance problem
