Ironhead A place to talk about Ironheads.
carb poping
Old Apr 13, 2007 | 08:06 PM
solitaryman54's Avatar
solitaryman54
Default carb poping
hi all; just came back from a little run with my 80 sporty. seems to run good got the timing down fairly well. except every now and then the carb back fires through the carb when i excellorate. I was screwing round with the idle lean rich screw and the excellorator screw. could i have got these out of adjustment? its got on it a s&s e carb the displacment is 1000 cc.the adjustment screw for lean or rich was fairly easy the other one i'm not so sure. thanks for alll your help larry
Old Apr 17, 2007 | 09:15 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Default RE: carb poping
Sounds like the main jet is too small or the accelerator pump is not working right. If it's the pump, the problem probably won't happen if you roll the throttle on slowly.
Old Apr 18, 2007 | 09:29 PM
mojo2go's Avatar
mojo2go
Are your intake seals and clamps in good shape? A leak at these would cause that problem.
Old Apr 23, 2007 | 01:18 AM
pitbull1's Avatar
pitbull1
popping in the top means you are running lean guy..probably the intermediate jet,,you may be able to adjust that out with the pump..
1/2crazedbikr
EVO
15
Dec 10, 2022 03:59 PM
Ironhead Dave
Ironhead
25
Jul 11, 2016 09:35 AM
skinman13
Jun 30, 2014 02:43 PM
EvoFatboy
Exhaust System Topics
15
Jan 28, 2013 07:43 AM
jaysledge
Engine Mechanical Topics
Aug 12, 2011 11:54 PM
