Carb tuning
Old Jul 17, 2011 | 11:10 AM
jaysledge's Avatar
jaysledge
Default Carb tuning
Here is my problem, I can't seem to get the carb adjusted correctly. It has an idle problem, popping and shooting flames out of the exhaust and carb and carbon coats the plugs after 15 minutes.
It won't idle unless the idle adjustment is almost screwed all the way down.
Tried to adjust the idle mixture and enrichment device and they don't seem to do anything in either direction, and the accelerator pump adjustment screw doesn't seem to do anything either.
Also, the throttle is acting weird, I use it to speed up, but letting go and it doesn't decelerate. The cables aren't sticking because they work when parked and the first two gears, but 3-5 it's a different animal.
It is a Super E Carb, moved from guflport area (sea level) to mountains. Elevation is 3500', ran fine then but now it is jacked. Had a shop look at it and even they are stumped,because we tried the jet change out too. Any ideas???
Old Jul 17, 2011 | 11:53 AM
Wild Card's Avatar
Wild Card
plugs say way rich, but your altitude relocate should have gone lean, sounds like I would pull the carb and rebuild it, at minimum make sure the float is not sticking and seating properly and keeping the right level.
and this mechanic that is stumped, find another
Old Jul 17, 2011 | 12:35 PM
JohnFlorida's Avatar
JohnFlorida
Maybe your choke is getting stuck
Old Jul 17, 2011 | 03:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Moving from sea level to 3500 feet altitude would make the carb mixture rich, the jets stayed the same but the air is thinner...
Agree with the float sticking, or possibly crud in the carburetor.
Old Jul 17, 2011 | 11:49 PM
Quad D's Avatar
Quad D
Maybe you choke is worn where it sets in the carb. If you use the choke often, or if someone owned it before you used it often it may be worn and allowing fuel by even when in closed position.
Old Jul 19, 2011 | 01:35 PM
jaysledge's Avatar
jaysledge
Thanks for the info, while I was working on that, found some broken wires too, man this bike is turning out to be a garage *****.
Old Jul 19, 2011 | 03:22 PM
JohnFlorida
They all are till you get em right
Old Aug 12, 2011 | 12:37 PM
jaysledge's Avatar
jaysledge
Ok, took y'alls advice, had carb rebuilt by another mechanic, runs like a raped ape now. Thanks for taking the time to help me.
Old Aug 12, 2011 | 11:54 PM
Quad D's Avatar
Quad D
Good deal man, it's nice to be on the road rather than wrenching.
backwoodsdave
Shovelhead
Jun 27, 2018 12:35 AM
buellxb422
Ironhead
Apr 25, 2016 08:13 AM
lowflyer
Carburetor Related
Aug 18, 2014 08:20 PM
stokes
Jun 13, 2011 06:58 AM
bubba_d_duck
May 5, 2007 12:27 PM
