carb issue
Old May 5, 2007 | 09:44 AM
bubba_d_duck's Avatar
bubba_d_duck
Default carb issue
i was wondering if anyone knew the right way to adjust an S&S carb on a 1980 1000cc bike. i tryed messing with it and it idles a little lower now but in first and second i have to play with the throttle because the bike starts bogging down. wide open the bikeis fine but once i back off the throttle it bogs down. any help would be appreciated. thanks
Old May 5, 2007 | 11:29 AM
drum412's Avatar
drum412
Default RE: carb issue
Is the bogging down something that just started, or has it always ran that way? If it just started happening, I'd start off with a good carb cleaning to insure all jet passages are clean and flowing properly. Also check the float level, a low float level can cause unstable flow between idle and 1/2 throttle when the main jet starts to kick in. I don't have s&s, so I don't know any specifics for adjustments, but in general most carbs use a fairly simular tuning procedure, wether it's mikuni, keihin, bendix, s&s. the mikuni carbs have a pretty decent tuning guide on their website, not sure if s&s offers anything, but you could try e-mailing them, i've heard their costumer support is pretty decent.
Old May 5, 2007 | 12:27 PM
bubba_d_duck
thanks i will try emailing them. the bike has done this a little for a while but just recently it has gotten alot worse
theundeadelvis
EVO
20
Oct 28, 2013 08:32 AM
jaysledge
Engine Mechanical Topics
Aug 12, 2011 11:54 PM
Bama91
EVO
18
Jun 12, 2011 03:24 PM
chopmafia777
Exhaust System Topics
Sep 21, 2009 09:19 AM
Pauly
Jun 8, 2006 10:48 PM
