Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Thunderjet tunning? Need help
Old 06-27-2014, 10:43 PM
DynaRobert82's Avatar
DynaRobert82
DynaRobert82 is offline
Default Thunderjet tunning? Need help
Ok so I have searched and cannot find what I'm looking for so I thought id ask you guys. I got a super g with a thunderjet on a twin cam 95" build with redshift cams. I can't figure out how to "tune" or adjust this carb. All the other s&s carbs I've messed with I just lean to a stumble and richen to a stumble and set it right in the middle. Now if I do this with this carb with the thunderjet I keep getting this pop thru the carb when I'm slowing down to a stoplight or sitting at a stoplight. If I richen it up then it sometimes pours gas out the front of the carb. So I dunno. Hope you guys can help out.
Old 06-30-2014, 10:32 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You may have an air leak between carb and one of the heads, causing the popping. It's worth ensuring things are OK there before changing the carb settings.
Old 07-01-2014, 03:50 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Sounds a tick lean.
May want to bump the pilot jet up 1 size, but if it was dyno tuned, by someone that KNOWS those, your woes would be over.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Tcmuzzy88
Exhaust System Topics
08-07-2020 12:43 PM
Cliff1970
Shovelhead
04-15-2017 09:50 AM
01 chopper
05-16-2013 07:17 AM
1sandking1
07-05-2012 10:12 PM
92redFLHS
06-07-2007 08:50 PM
Quick Reply: Thunderjet tunning? Need help
