Carb Issue?
The old ones could be sucking air which is a no-no.
Gaskets are less than $10 bucks but installing them is a pain unless you have the proper tools.
Some folks (I'm told) also use a propane torch (unlit),holding the nozzle near the intake gaskets to see if the engine RPM's increase.
I've just put two sets in our EVO engines, and I had an indy shop install them in my T/C 88 just this week.
THe tech told me that he has replaced them on bikes less than 4 years old but he didn't mention mileage.
On the two EVO's that I just done (one less than 9,000 miles, the other at 25,000 miles) the ones off of the engine with 9,000 miles appeared to be in worse shape than the one with 25,000 miles.
Like the tech told me, those engines go from ambient temps up to close to 300 degrees and then repeat that time and time again.
It's not a matter of will they will go bad, but when?
