How ti identify a Harley frame?
I need some help and advice.
I am searching for information of how to identify a frame being an original Harley frame.
Both in general as well as more specific for FL/FLH with Shovelhead engine.
It could be books, pictures, links etc.
This is in order to make a manual for the authorities here in Denmark, so that they can identify original frames from non-original. In Denmark you will basically lose the registration of the motorcycle (and the taxes paid) in case you cannot prove the originality of the frame.
Thanks in advance - your time and effort is highly appreciated.
Peter
Peter
Peter
Peter
I would be more concerned with altered numbers on 70 and up frames. One scam involves obtaining a title to a Harley Aeromachi lightweight or Sportster and transferring those numbers to a FX/FLH. Original Harley frames are easy to identify with the part numbers cast into the rear sections as noted above.
The frame in question - it is documentation for an FL/FLH, that can prove the frame being original with a Shovelhead...?
Peter Panhead
01-14-2015 12:46 PM
