Front Motor mount question
Any help will be appreciated fellows, but can anyone tell me what to look for to determine if I need a new front motor mount. While riding recently I hear a metal to metal noise in the front end when I hit bumps in the road. I know here in Okiehomer, but this happens on the more severe ones.
You would have to have a serious issue with a motor mount to have metal to metal sounds. Usually the 2 rubber pieces make contact and transfer vibration into the frame. There is supposed to be a small gap between the upper and lower part of the mount. usually the only issue that arises from them making contact is increased vibration at speed
I second checking the gas tank to be sure it isn't moving.
Loose gas tank bolt. Tighten her up.
I had the same noise up front. It was a broken mount. I made a video.
https://www.hdforums.com/forum/dyna-...placement.html
