88TC: to Big Bore or Cam?
I know there are dozens of threads on this but what's one more?
I have an 05 FXDL, 88". Already have stage 1. My local shop quoted me $2k for S&S cams, chain tensioner/oil pump upgrade, pushrods, rejetting carb.
Local HD dealer quoted me $1200 to have the 95 kit (boring my stock cylinders), SE pistons, install + carb work.
I know a lot of you will say "save your money and do both at the same time", but I don't think I'll ever be comfortable enough to drop $3k on this bike at one time. I want a little more OOMPH but I don't want to invest 3k in this bike.
That said...BANG FOR BUCK...would you drop 2k for the cams or 1k for the big bore kit??? This will probably be the last performance upgrade I do to this bike...
Ummm no... its the other way around. We go TO gear drive cams to eliminate the cam chains/tensioners and the risk of failure. Makes the drive train MORE dependable...not less. If your crank is good...definitely go gear drive.
Received 4,368 Likes
How many miles on said engine? I used HD 95" kit (cylinders and pistons) and had 203 cams installed. The carb you can upgrade your self. Look up Joe Minton on Google, he's got good ideas on how to tune the carb. I followed his instructions on my 02 FXD, bike pulls real good with two up. Good luck and have fun.
