Moving bars
Old 01-26-2015, 04:50 PM
stbobshadow's Avatar
stbobshadow
stbobshadow is offline
Default Moving bars
I have 16 in apes and when I hit decent size potholes they will move. I have them tightened to spec and they are kurled. Thought about removing the riser clamp and drilling hole front to back and putting a small pin at the desired position and clamping back down. Anyone see any issues with this?
Old 01-26-2015, 04:59 PM
robbyville's Avatar
robbyville
robbyville is offline
Are you sure it's not the bushings moving?
Old 01-26-2015, 05:43 PM
acky1946's Avatar
acky1946
acky1946 is offline
Assuming you have the stock rubber bushings in there now I'd try some new poly bushings and see if that makes a difference. The higher the bars the more they tend to move,
You could also try solid type "bushings" but the comfort goes down a bit. Both poly and solid are a cheap fix.
Pegging them, as you suggest, is also an option. I did that a few times on various H-Ds I owned with high bars. That always worked for me.
Good luck with your fix.
Acky1946
Old 01-26-2015, 06:03 PM
rallsqh's Avatar
rallsqh
rallsqh is offline
You can also take a large grit sandpaper, fold it in half so the grit is showing on both sides, wrap that around the bars and put your top clamp back on. I have had good luck with this taking a lot of the movement out of my bars.
Old 01-26-2015, 06:15 PM
stupid_rope's Avatar
stupid_rope
stupid_rope is offline
i wrapped grip tape on the knurled part of the bars under the clamp. sandpaper works too
Old 01-26-2015, 07:45 PM
stbobshadow
I have changed the rubber bushings and it's the bars that roll in the clamp when I hit bumps in the road. Not all of the time but enough to **** you off.
Old 01-26-2015, 10:22 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Put some drag bars on her. Problem solved!
Old 01-27-2015, 01:53 AM
Deadhead77's Avatar
Deadhead77
Deadhead77 is offline
Skateboard grip tape worked perfect on my 16's. My bars are rock solid now.
scottylonebull
09-19-2017 02:54 AM
rcrown
11-06-2016 05:57 PM
BlueNoser
09-26-2010 05:12 PM
ptl203
08-20-2010 06:52 PM
wolf1477
Ironhead
06-04-2006 07:17 PM
Quick Reply: Moving bars
