Dakota digital gauge
Well, this turned into a good topic.
I'll be ordering one, but like I said, its more to get rid of the "bug eye" double gauge setup.
Gear indicator and such isn't really a big deal to me. Although I might come to like having it.
Speedo and tach are what I'm after. In one unit.
Thanks for all the input.
With all the guys running them, I'm surprised it isn't talked about more often.
Super easy - just buy the sending unit that DD sells, I installed it in the oil pan where the drain plug was - run a wire to the console and then it plugs right into the speedo/tach......10/15 minute job.....
I used the SEN-1043 - oil temp sensor and just screwed it in place of the oil drain plug -http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=329/category_id=-1/mode=prod/prd329.htm
Than as I said before, I just plugged the wire into the speedo/tach, spliced and ran it down the bike to the drain pan, crimped on a female spade connector and attached to the sending unit...
No wire diagram needed - plug & play - easy peasy - but here is the tech sheet from DD- http://www.dakotadigital.com/pdf/mcl-2004.pdf
Let me know if you have any other questions
The real model and size?
Hey guys, spent all night looking for a new gauge and this thread has been the most helpful.
Now every website has conflicting model number with the fatbobs. Mine is a 2009 FXDF model and it will come up as the MCL 3204 model being the right one, even on Dakota Digital website. However they list it as being 3 3/8" in diameter. This is confusing since the fat bob gauge diameter is 5", therefore the model MCL 2004 would be the correct one.
JCM has the MCL2004 and the dude that posted before me has the 3204.
Which one is the right one?
All of those with the "newer" 3204 model could post a pic to show how they look like?
And why the heck Dakota Digital doesn't seem to have it right on their website??
Looking forward for a reply so I can purchase this.
ATT.: not sure what model the guy from this pic bought, but sure as hell it looks dumber than a football bat.
the pic I attached is from a model that was smaller, prob a 3 3/8in, therefore the shop had to fit the smaller gauge into a larger bezel and fit into the fatbob. Notice how much smaller the gauge look compared to JCM's.
The gauge looks good to me, I just want to make sure I am getting the right size and not have to fix anything or figure out how to fit it if its not the correct one.
