Finally modified big sucker backing plate.
finally took the time to get this done hopefully will be riding soon. remove the breather and backing plate. center punched both bosses directly under where the holes that lead to throttle body throat . drilled a pilot hole with a 1/8 bit and finished with a 21/64 drill bit and than tapped 1/8-27 npt . and had two 1/8 x 1/4 compression fittings put on 5/16 stainless braided hose. routed to the center, used a 5/16 vacuum tee and a external breather purchased from advanced auto. wanted it kept clean looking and like the thought of keeping my engine oil full. that 1/2 to 1 quart low is not the proper repair.
suede
when i ride it hard get some oil out of breather now and then. not as bad as when I had the smaller head work. have 5000 miles on new engine after tune took off air filter and opened up throttle body could see it was dirty. used a cotton rag and rubbed it around intake area. rag has oil residue on it. used carb cleaner and cleaned all of intake area into the heads. used my bore scope and looked in cylinders there is a small amount of residue on top of pistons. not bad, when its gets warmer outside will get engine up to temperature and use some GM top engine cleaner and give it a thorough cleaning.
used a drill press, wash all down after with brake cleaner, air dried and used high temp silicone in the pressurized cans to push the silicone all the way through.
