2012 FXDC brake upgrade options? opinions/advice please
First, yes I read the sticky on doing the dual brake conversion and have also done a handful of searches here and on the all knowing google.
So I have a 2012 FXDC that I got back on new years, I've recently put on a bassani 2-1 Mega power exhaust and have an RSD Venturi Air cleaner I'm going to put on in the morning, along with a power vision for the tune. I used to ride sport bikes before getting the Harley, last bike was a Daytona 675R, and I find the brake on the FXDC to be more than merely disappointing. Now I don't expect that any of these options or really anything will get me the braking that I had on my Daytona but I'm looking for some serious improvement.
Option 1: upgrade from the stock single I have to a better caliper, from what I've read sounds like a favorite is the 6 piston PM, while this seems to be the simplest option and probably the cheapest it will provide the least amount of improvement, and I worry it won't be enough to make me happy. I figure the cost of this option is just the cost of the caliper so around $400-500. The issue being I have an 11.8" rotor stock, if I'm not mistaken, and all I'm finding for PM calipers are for 11.5" and 13", so I might have to swap to a smaller rotor
Option 2: much like option one except upgrade to 13" rotor, from there I believe I should be able to use either a 6 piston PM or a Brembo brake. Cost on this I'm not sure of, I'm really not finding much in the way of 13" rotors that I'm sure will fit, would need to do research but I'm expecting more on the level of 700-800 with the bracket for this option.
Option 3: convert to dual disc setup utilizing stock dyna calipers, now these will be more work intensive but I think have a much better shot of giving me results that I'd be satisfied with. I'd need a 11/16" master cylinder, brake lines, right caliper, 11.8" right rotor, and right fork slider, most of which I can find used pretty damn cheap, with the exception of the fork slider which I'm finding nothing for so far. With some luck I can probably get this all for around 500 maybe less if I can manage to find a fork slider. Only cons to this option is sourcing the parts, and as crappy as the stock caliper is I wonder if having another crappy caliper will make much difference, which leads to:
Option 4: Convert to dual disc setup using Brembos, much the same as option 3 except now instead of stock dyna calipers I get brembo ones from the touring models, price jumps up another 100-150ish from option 3, issue with this is I keep hearing talk about the sweep area or something on the rotor from the brembos not being right or not lining up right, but it also seems that everyone who does this has been at least initially happy with the choice to do so. I'd love to hear from anyone who did this a long time ago, from a mileage/use stand point have you had any issues, is this sweep area thing a big deal?
Now obviously option 1 and 2 could be a lot cheaper if I can find the parts used, I'm just really not seeing them out there, where as there is a plethora of used parts for option 3 and 4, with the exception of the right fork slider.
If I'm missing something, please let me know, I'd like to hear your advice and opinions, obviously or I wouldn't be posting, any sort of data or pictures or explanations as to why would be extremely welcome as well. Thanks in advance.
there's lyndall rotors and pads you could throw in as an option - not cheap but apparently quite the upgrade, especially with an aftermarket calliper
the arlen ness big brake looks interesting and i'm considering it, possibly the best bang for your buck
if you're looking at aftermarket callipers check out Jaybrake, I have a 6-piston from them and it was a good improvement, probably even better with lyndall pads or the big brake...
That arlen ness big brake kit, if I can then put a brembo on it... that might be just the ticket. Looks like the Jaybrake I would run into the same issues as the PM 6 piston, would need to either switch to 11.5" rotors or 13". If I were to go to the arlen ness 15" rotor and a brembo from one of the touring bikes, would I be able to use my 9/16" master cylinder still or would I still need to move to the 11/16"
I see what you did there... give me more things to look up and research and buy, you almost had me. I'll look into that, trying to budget one project at a time, but you're right if I'm already in there I kind of might as well.
