Long time reader first time poster here. I have a 2011 street bob that had the big rear brake light on the fender which cracked. I swapped it for a fender from a 2014 bob without the brake light. Before i did the swap my turn signals were run/stop and turn. So i was just going to use them as the brake lights also. But now i dont have brake lights. Run and turn only. The wires that were plugged into the old brake light arent plugged into anything now. How do i get my turn signals to be brake lights again? Do i splice the old brake light wires to the turn signals? Or Do i need an stt module? Im not real good with electrical stuff. Any help would be appreciated. Thanks!
Fuses are good. I changed handle bars at the same time i did the fender. Dont know if i could have pinched a wire there and messed it up or what. Not sure what i did lol..... What did you do with the wires for the old brake light?
Check your bulbs also, as simple as that sounds. When I changed my wife's handle bars, the turns and brakes were out on one side. Changed the bulbs and they were fixed.
I removed the brake light lead from the harness (where it plugs in under the seat). I reused the running light and ground that was for the taillight, and used them to power a side mount license plate. If u run a side mount plate with a brake light in it, these extra leads will be perfect!
