Gonna install 12" Wild 1 Outlawz
I have a 2015 Street Bob and i'm gonna install 12" Outlawz with internal wiring. Anything I should be aware of in the process ?
I've heard the wireplugs on the 2015 is small enough to fit through the handlebars, so you you should'nt have to disassemble them. Anyone that can confirm this ?
Let us know how the install goes. I have the same bike and I've been considering the same bars for a while. The issue I've had is removing the turn signals from the handlebars. I'm not sure how to remove the wiring from the signal without just pulling on it so I can thread it back through the bars.
I plan to put 12's on my S Bob as well. I haven't done much research in how the process works yet but these "connectors" are you talking about the wires that run under the gas tank?
Also, anyone switch to Poly Bushings? I've heard they take out a lot of high speed vibration. Any specialty tools I should consider for this job? Any tricks to help make running the wires through the bars easier?
Thanks!
Thanks!
