turn signal and high beam indicator light replacement
I have a 2012 super glide custom and the light on the tank panel that indicated when a turn signal is on and the high beam indicator light is out. Is this a big deal to fix? Exactly what would I need to replace these lamps. Thanks.
Thanks I did that, everything was plugged in and looked normal. I guess I will have to take it to the shop and use my extended warranty! First time for everything! It's unusual for just two led lights to go out on that board so maybe it is something else.
Heck if you got a warranty I think you are overthinking this a bit! I would think it's a problem with the board. Happens from time to time with LED's. Usually when one of those quit lighting it's a whole replace. Downside of LED's.
