Poor Throttle Response
Hey guys,
I've got a 2008 Street Bob with 16'' apes and extended cables. I bought the bike used with the previously mentioned set up. However, there is a lot of grittiness and tension in the throttle. It is very hard to turn and it sluggishly snaps back into place. I've tried adjusting the cables to no result. Is it because there is so much extra cable or a different problem?
Thank You
Thank You
Had same issue after swapping my bar setup. I would check the stuff most people mentioned, check cables seated correctly and lube cables. For me when I put the controls on the bars I tightened down the master cylinder and front brake lever before the switch housing and the throttle tube / switch housing needed to be push on like another 1/8th or 1/16th of an inch. When that was tightened it pushed itself on and it was causing the throttle tube to rub the inside of the switch housing causing it to stick or slowly snap back. I just loosened up the switch housing and clamp for brake lever / MC, made sure everything was pushed on the bar all the way then tightened the switch housing first and then the brake lever and everything was back to normal behavior.
hdpearson13
03-30-2008 12:07 PM
