not good...melted battery!
Old 12-20-2015, 06:03 PM
SwarleyManson62's Avatar
SwarleyManson62
SwarleyManson62 is offline
Default not good...melted battery!
Hey guys, hoping for some guidance here.
So was riding with a buddy to pep boys...luckily i broke down in the pep boys parking lot or so i thought. Went to start the bike when leaving, then smoke from the battery compartment. So opened it up and my negative terminal was melted. Figured the connection was just loose and i had bad luck!
Unfortunately that doesn't seem to have been the case. I put a new battery in, went to start it. Nothing. I turn the key, the headlight comes on but thats it. No fuel pump, no gauge etc. On top of that i turn the key back to off and my hi beam indicator stays on. I had to tow it home and now i'm pretty much at a loss from here.
any help would be appreciated
Old 12-20-2015, 06:24 PM
sengle4's Avatar
sengle4
sengle4 is offline
pull and check all your fuses.
Old 12-20-2015, 06:44 PM
USAFANGWINGNUT67's Avatar
USAFANGWINGNUT67
USAFANGWINGNUT67 is offline
Same thing happened to me on my '12 Sportster. Battery was changed earlier this year. Had to have it towed to HD dealer who found out that the negative terminal of the battery came loose and melted part of terminal and battery.
Old 12-20-2015, 06:45 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
First, you're probably right about a bad connection as the first problem. If battery connections are not tight and/or not clean, arcing can result, and the lead will melt.
However, that may have caused other, resulting issues. Sengle4 is right; start with all your fuses.
Old 12-21-2015, 01:10 AM
skinman13's Avatar
skinman13
skinman13 is offline
don't forget to check your voltage regulator. The loose battery connection essentially created a high resistance/intermittent connection that very well may have damaged the vr and or the stator.
Old 12-21-2015, 02:06 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,515 Likes on 6,271 Posts
Here are 20 threads about melted terminals. https://www.hdforums.com/forum/searc...rchid=32785889
Keep us updated. Good luck.
Old 12-21-2015, 06:36 AM
ROUNDHEAD's Avatar
ROUNDHEAD
ROUNDHEAD is offline
Been there, done that.
Lesson learned $126+tax.
Old 12-21-2015, 06:40 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
And...hate to say it...get yourself a service manual b/c it has the electrical schematics for your bike. Good for tracing electrical gremlins until you get everything back to working condition. Good luck.
Old 12-21-2015, 07:55 AM
skinman13's Avatar
skinman13
Intermittent power connections like you have described will cause voltage spikes that can damage sensitive electronic circuits like are found in modern vehicles. If you still have problems after you have the physical damage repaired (new battery and cable, checked all fuses and grounds), I suggest you start troubleshooting from that prospective.
Good luck...
Old 12-21-2015, 06:29 PM
SwarleyManson62
thanks guys...all fuses are good...now on to the rest of your directions!
Quick Reply: not good...melted battery!
