Oh yeah, head work time
#41
Hot damn, sounds like you got the works! I'm sure some of that noise will quiet down once it settles in and it gets out of the garage I'm a bit new to headwork specs but aren't 1.94 intake valves a bit big for the stock throttle body? Are you planning on an upgrade soon or will you be keeping the stock on? Cheers to your build!
#42
In fact, with a bit of basic math, given that the 46mm TB can flow 245cfm and has an area of 1662mm2, the 50mm TB should have an area of 1963mm - or 18% more than stock. This should equate to a max flow of 289 cfm. All rough theoretical numbers of course.
So it looks like an ideal match to Robby's (and my) heads.
Robby - where did you find these at $319 - I might spring for one!
#43
#46
#47
Sorry to get everyone's hopes up, feel like a real dufus. Ended up doing a fun color run with the family (my nose is still full of colored chalk lol), and temps here were 75 so I opted to run then ride! This weekend is looking like a winner, wife is pissed seeing manual and tools everywhere....
#48
https://www.hdforums.com/forum/image.../icon_cool.gif
On a positive note, I got mine all finished up last weekend and even got the bike out for a hour or so. It seems to pull like a train - especially from around 2500 rpm or so. No idea where it tops out yet, but it certainly got up to 90 in no time at all and I didn't want to go further as the roads were wet and slippy.
I did a half hour auto tuning run with the Power Vision, then refreshed the map, but haven't ridden it yet since then as I am out of the country on a trip.
I'll probably do a separate thread in the near future to show the process and results...
#49
So do you just stick with your base PV map and then auto tune even though you've had head work done or did you make some changes based on the work done?
#50
The bike ran great even before the autotune session - so no issues there.
