FXDF handlebar question
I did +6 all around. Keep in mind that the lower harness for the brake lines stays the same length (as wheel travel didn't change) just the top part is lengthened 6 inches.
Also the stock HD brake lowers don't work with aftermarket brake lines as they are a single piece (upper and lower), whereas the aftermarket (at least the Magnum cables I got) were 2 pieces.
Lastly, keep in mind that if you have ABS then the lowers are much more pricey.
Here is what you need to purchase:
Clutch Cable
Throttle Cable
Idle Cable
Upper Brake Assembly
Lower Brake assembly
I got mine from Magnum Sheilding. here is a direct link for your bike:
https://www.magnumshielding.com/inde...3&color_id=any
On the upper left hand side you can narrow down the search by color if you like.
I hope that helps. I was new to harley when I learned all this stuff so I had to figure it all out myself (I wasn't a forum member then)
Clutch Cable
Throttle Cable
Idle Cable
FYI, you can raise the stock risers 1" without any cable issues. I wish I could do 2" but the brake lines won't reach.
There is plenty of wiring in the frame (at least for my bike) I didn't need to extend it at all for the 10" bars. You have to remember, the stock risers are 4.5" tall, going to 10" is only a 5.5" difference in length. That means you only need an extra 5" of wiring. You'll most likely have that much there as well.
Frigol
10-29-2011 10:56 AM
