road rage differences
Received 2,189 Likes
Thank you all...
my confusion started here, i watched this:
the bassani seems to have the best sound (subjective). granted this is old. so i went looking for them and was met with 23 variants.
so i think the rr2 short will work but i have some questions...
- quality of black coloring/customization... I was thinking of doing chome headers/sheilds with a black megaphone and a chrome cap. i will clearly nee to call them on that nonsense but, has the the black faded or turned on anyone?
- how's the sound on the highway... does the RR2 (either) drone or fade with the wind noise?
i really don't want to hear blaring exhaust for hours at a time. my fxdwg is just for long hauls. the sporty is for around town/f**kery.
- i don't care about dyno performance etc... but the general consensus is that the torque curve shifts right, yes? so higher revs and tuning issues down low?
i had that problem with my sportster's grenades, took forever to get right... and it still isn't 100%. at this point, i feel that none of my bikes will ever see a dyno machine... i just don't care, that may change but, for now... no.
SO I have had both black, and now chrome. Bassani was great about cutting me a deal on a set of chrome shields, and the can. I decided to go with chrome after about six months of running the black shields. I like a little contrast on the bike, and I deleted a lot of chrome bits, so I decided to add the chrome pipe back on. The black wasn't really black, more like a dark charcoal gray... I believe all ceramic black systems are like this, regardless of manufacturer. The finish was top notch, and seemed to hold up well. I actually sold of my black shields and can, and the new owner has about 10,000 on them, and still no issues with quality. One thing I will point out, rubber boot marks are a biznitch to remove from the black pipes.
Power wise, I love mine. With a stock 103, and FP3, AC, and my Bassani, the bike pulls well in the low range, seems to smooth out a little in the mid 3000 range, then starts pulling hard again at about 3800 - 4800. It may actually keep pulling, but I generally do not spin the motor faster than that.
Edit: I forgot.... Do you wear ear plugs on the highway? I do, but only for wind sound. The pipe is noticeable at highway speeds, but nothing major, unless your rip the throttle. Idle is nice and mellow, but it will bark nicely when you get on it.
thank you, i'll give bassani a call and see if they will give me the chrome black combo i'm after.
I run the RR3 with original FXDXT bags (no heat shield).
I do not notice an excessive amount of heat on the bag after riding. I've been keeping a close eye on it and checking almost every time I stop, but the piece of fabric that wraps around the bottom of the mount does not seem to get hot. I haven't been stuck in traffic on a hot day yet; always moving so far.
I'm more concerned about the exhaust soot becoming a problem and making the bags dirty over time, but so far nothing to complain about.
I also always run buds in my ears, so noise isn't an issue for me. The exhaust barks nice and loud on hard throttle and sounds great, but I was pretty surprised how quiet I can keep it at low speeds if I keep RPMs low and short shift. (fairly stock 88ci). Idle is not as mean sounding as my stock headers with slip-ons were. More mellow. I'm sure that changes with engine setups.
Before I decided to go with the RR3 I was considering the black Road Rage Short (1D5250B). FWIW, best price I found was Direct Cycle Parts.
Good luck.
-G
Good luck.
-G
I do need to make a small lower heat shield to go right behind the foot peg though, as the heel of my boot sometimes leaves some black melty stains right there. I've been able to remove it so far with steel wool, but it's annoying.
And btw, there is PLENTY of cornering clearance with this pipe.
-G
That was my thought as well, but I tried installing the one heat shield in that location and found that the two head pipes basically touch each other right there, and there isn't even room to feed the clamp through (at least on mine). I'll try again, but I was kind of thinking that I would have to make something that would install around both pipes there...
You're fine then if you have plugs or buds in... If my plugs are soft, and getting ready for replacement, I can sometimes hear a little motor hum, but the wind still overpowers the pipe.
How do you like riding with ear buds? Been thinking about it, but part of me feels like it might be a little sketchy.
