Dual Gauge / Micky Mouse Set-up Quetions
Received 2,189 Likes
Dual Gauge / Micky Mouse Set-up Questions
I'm finally ordering the parts for the dual guage set up on my dyna. so far i've ...
I've got some questions. until i get a hold of a super glide tank.
i know that's a lot to be asking but, there are so many variables.
ordered:
using the 2008 roadster as my source.
http://partsfinder.onlinemicrofiche....R%20ASSEMBLIES
ordered:
- 67103-95 TACHOMETER COVER, BACK, CHROME x 2
- 67338-97 SPEEDO/TACH BRACKET x 1
- 692006-15 WIRE HARNESS,INSTRUMENT ASY x 1
- 74541-00 KIT,COVER,BEZEL GAUGE,INSTRUMENT x 1
- 670000-10 TACH,4/5500 RDLN,BLK/SS x 1
what to do about:
Will be using the lucky dave's bar mount for gauge cluster.
http://luckydaves.com/product/gauge-mount/
any one used this? what size screws/bolts did you used to secure the cluster bracket?
also, are there things that's i'm not even considering that will probably slap me in the face?
- the ignition switch?
- extending the wires? i see that some hack and slash the wires, others are kits... any info here helps.
- gaping hole left by the speedo?
stonei3 (02-17-2017)
Sorry to flood the thread...found another pic after I'd hit the piece with some flat black to blend a little more and I plugged the indicator hole with a dummy piece that wasn't actually hooked up, but it filled the hole.
The website for the speedo plate is www.conflictedindustries.com
Don't know about the LD hardware but Accutronix comes with all the hardware you need.
http://www.ebay.com/itm/Accutronix-G...-/121830569034
cvaria (10-09-2016)
And it doesn't have tacky LD on it. Thanks, i'll use that instead.
