Raked trees
I've not done it so I can't comment on doing it.. One thing to note is that what can also be done increase fork neck rake is to use shorter shocks in the rear and longer forks in the front end. Both mods rotate the static position of the frame to increase the angle at the neck. It like the guys that are selling raked trees are making those changes.. They add 2 inches to the forks and look to be using shorter shocks in the back. I suspect the prostreet look where the frame is level and low will need more frame rake than 29 degrees.
I agree that it would be nice to discuss this with someone who has done it..
.. The extra inch of 2 over tubes will raise the front end a bit..
I know there are guys on here that have done it. Perhaps now they don't want to admit it? :-D
Seeger says to drop the rear 1" and either run a 21" rim on front, or 2" over tubes with the original 19" with their 5 deg. trees. I would prefer to have the neck angle changed, but I guess the guy I talked to in Dallas needs to catch up his beamer payments, and I can't see it. Don't even know his reputation for this mod, and could well end up with a junk frame. At least with trees, it's easily reversed.I'm going to do this, and we'll see what happens. If you don't see me post anything after it's done, they must have scraped me up off the highway...
Originally Posted by bwoltz
Technically, raked trees will will make it a handful at speed.. Raking trees decreases trail which causes high speed stability issues.. Raking the steering neck increases trail which makes low speed harder but increases high speed stability.
BTW, here's the Vulcan kit being installed...Also more pics of the Tool in later pages
https://www.hdforums.com/forum/sport...l#post15836839
Not E'nuff Harley (01-20-2017)
I will. I'm not concerned. The cups are marked and locating center of the stem is an easy task. Should be doing the install next weekend.
