21 & 18" wheel question
Old 03-13-2017, 08:14 AM
Msmth218's Avatar
Msmth218
Msmth218 is offline
Default 21 & 18" wheel question
Just picked up an 06 street bob and plan on purchasing the Burly Slammer kit. Question I have is if I will run into any issues running a 21x3.5 wheel in the front and an 18X5.5 rear in the wheel. Tires will be a 120/70 and 200 in the rear. Is there anything I need to be aware of and is will I be able to adjust the height either in the front or rear with the slammer kit?
Old 03-13-2017, 09:00 AM
jmeiers's Avatar
jmeiers
jmeiers is offline
No problem up front.
Rear will need slight mods to inner fender brackets and likely removal of stock-style rear turns signals, taillights, and associated wiring.
Old 03-13-2017, 09:14 AM
Msmth218's Avatar
Msmth218
Msmth218 is offline
thanks for the quick resposne...will remove the rear turn signals and will have vertical license plate mount with tailight, so should be good then...how about riding 2up, any issues there? I won't be riding 2up often but just curious?
Old 03-13-2017, 09:16 AM
jmeiers's Avatar
jmeiers
jmeiers is offline
Although I have no experience with riding 2-up on my bike, there should be no problems with that either.
Old 03-13-2017, 09:20 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
Originally Posted by Msmth218
Just picked up an 06 street bob ...Question I have is if I will run into any issues running a 21x3.5 wheel in the front...Tires will be a 120/70
Are your re-lacing your hub (assuming you have laced wheel) to a 3.5 hoop or did you find a Mid-glide wheel?
Old 03-13-2017, 09:41 AM
Msmth218's Avatar
Msmth218
Msmth218 is offline
will re-lace to 3.5 hoop
Old 03-22-2017, 10:56 AM
Msmth218's Avatar
Msmth218
Msmth218 is offline
Will I have to find another hub for my streetbob if I want to run a 21x3.5 80 spoke DNA wheel for the front and 18x5.5 rear wheel or can I use the stock hub?
Old 03-22-2017, 11:01 AM
multihdrdr's Avatar
multihdrdr
Will I have to find another hub for my streetbob if I want to run an 21x3.5 80 spoke DNA wheel or can I use the stock hub?
Go out and count the # of spokes on your stock hub...What do you think?
Old 03-22-2017, 11:11 AM
Msmth218's Avatar
Msmth218
Msmth218 is offline
just found the answer as well...which hub can I use or where can I source a hub that will work on my bike?
Old 03-22-2017, 11:51 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
5.5" is kinda narrow for a 200. It's doable, I've got one, but please ensure the chosen tire is rated for a rim of that width.
As for a hub source...
Hdwheels.com
Ultima
Demons cycle
DNA
Ridewright
etc.
Be prepared to pay for quality.
Quick Reply: 21 & 18" wheel question
