how to cover top part of forks between triple tree
Ok, so I am well off to painting my lower legs black, got the rubber fork boot ordered and now I am trying to find out how some of you have covered the part of the forks between the triple tree. I could only find alittle info on this and am looking for the best way to do this, or at least one that I can get the items to do. i tried a search and it came up with nothing.
Thanks for your time to respond.
RE: how to cover top part of forks between triple tree
You can just get black decals like the carbon ones and do that. Only problem is that you might have to peel it off to pull the forks outta the clamps if you ever need to do so.
http://www.motosport.com/offroad/pro...&cat0=DIRT
Your HD dealer has some metric as well right? You should be able to go into the parts department and ask for carbon fork guards for an MX bike. They should have them in stock just make sure they will suck down on you 49mm forks and are long enough. Maybe that shop down by Ely and Visa Way would have them, they should be $40 to $60.
Old trick, but then, I'm a very old biker.
Back in the "old days" we would extend the front end by installing "slugs"(now illegal) that were steel sections the exact outside diameter as the fork tubes, with threads on the bottom that would screw into the top of your stock forks and threads in the top end that the tube caps screwed into. You could buy slugs in 2"-4"-6"-8"
Now, back to the subject.......in order to cover these slugs, we would go to the hardware store and buy chrome plated brass tubes that were made as drain pipe on sinks (kicthen/bathroom) these tubes were slightly bigger than the fork tubes. We would cut them to fit between the triple trees and slide them over the tubes.
Quick - easy - low cost
C66
C66
I don't know the web site or manufacture but I have seen somewhere on the web a company that makes all kinds of designed solid leather wraps that I think are a velcrow wrap over....If I run across it I'll jump back in and post....do the same if you find it....good luck.
I really like these ideas. I just had a thought. I am running a Memphis Shades windshield for the long trips and well guess where the fork clamps clamp to. yep that exact area. So here is one I thought of from one you the ideas here. What if I use some leather. A piece that would cover the whole area, not in straps but one piece that is either velcro'd in place and then the the windshield clamps could then clamp over it when needed. Just an idea. I really appreciate all the great ideas.
Been thinking about this myself - two not very expensive ideas, neither of which require removing forks:
1) Leather covers with lace ups in different patterns:
http://geoleather.com/upperforkcover...orkcovers.html
Or,
2) I've also heard that you can get PVC pipe at any hardware store, cut it to size and slit it vertically, prime it and paint it (any color), then open it up a bit and snap it over the top forks. Easy on and off. Not sure about this idea but cheap and worth looking into I'd think, if you can find the right inside diameter on the pipe. Might also want to put something around the forks to keep the PVC from marring the finish if it slides around any or a small piece of velcro to hold it in place and keep the slit/cut to the rear.
Good luck and let us know what you come up with.
Chip
Or,
Chip
