Seriously, I need some help here. \\; My I have the axle nut and both lower shock mounts off. \\; The axle adjusters are backed out and loose. \\;
My manual says in the rear wheel removal section to remove the brake caliper assembly, then remove the axle. \\; But in the brake section it says remove the axle, THEN the caliper.
Mr. Puddle,
 \\; \\; I have the belt off, and have hit it with a hammer dampened with a wood block. \\; The bolt turns, but will not back out. \\; The bolt should just come out over the muffler, right? \\; Do I need to remove the brake caliper?
The axle bolt goes through the caliper It must be in a bind to be that hard to remove. Be sure and remove the upper bely guard or you will get hung up on it.
