A little Unstable
A little Unstable
Hi All,
Newbie to the Forum, newbie to my Wide-Glide. Riding about two months, so far great. Really great.
Last weekend I put on a WindVest, 16" and some saddlebags. All week it feels like I'm a little wobbly, unstable, I even thought I had a rear tire going flat. Ride doesn't want to hold a straight line and turns feel a bit "soft". Before the Windvest it felt more stable, even though the wind blasted me pretty good over 70mph.
It's an '05 Wide-Glide, Street Slammer bars, WindVest and Just Leather bags. The bags aren't loaded full or heavy, just an extra jacket and coffee thermos. Just did 15K service at the HD dealer. Nothing wrong.
Any thoughts would be appreciated. I'm not feeling too comfotable over 50mph and I've spent all week in the slow lane.
Thanks,
DD
Thanks,
DD
If by "Windvest" you mean "Windscreen" there was a guy on here that had a problem with his on here a few days ago...he practically said the same thing. Anything over a certain mph he said his bike would get a little wobble or sway...It may be the wind screen flexing higher speeds because now it has to hit the wind screen b 4 anything...just my 2 cents
Yes, WindVest is a brand. Smaller style windscreen. I really liked the looks better than most of the orthers.
No, I haven't adjusted it yet. It's mounted in the mid position. I figured this weekend I was going to remove it, ride for awhile, remove the bags, ride some more, put the WindVest back on, ride again, bags back on, etc. etc.
Also stopped in at the dealer tonight. He thought possibly shocks, so I bought a Spanner and tightened them up one notch. I'll see if that did anything, good or bad in the morning on the way to work. I'm betting he just wanted to seel me part though.
Thank you both for the input. I appreciate it. I'll try to find that other post and see if any other suggestions were made.
The bags should not be making any of this happen, I have bags on my 05 WG and no difference with or without them. This is why I have never liked windscreens, I ride for the wind, why block it? Or attempt to that is.
Anyways, I would pull the windscreen and see if that eliminates the issue, if it does then play with the positioning of it till you find a spot that works, if you don't find that spot, lose it.
I have the compact standard height quick release windshield made by Harley.
While testing for front end wobble, if I take both hands off of the grips and watch my front end, it will wobble slightly with the windshield on.
If I have the windshield off and do the same thing, there is no wobble at all.
I can't feel the wobble while holding the bars, and it definitely has not changed the way my turns feel.
Try taking the windshield off and see if you notice a difference.
I don't know if this is your problem or not, but what can happen is that a windshield can create lift thereby decreasing the weight on the front tire to where is has very little contact with the road. Try stiffing up your rear shocks a bit in an attempt to increase the weight on the front wheel.
Also tilting the shield back may help some.
