I've always liked the look of drag bars so I'm looking at putting a set on my 07 Dyna Custom. Can anyone tell me what size works best? I'm 6ft and the bike has forward controls but I want to use the stock cables and controls. I see there and 6"& 8". I like the ones with the one piece risers.
Check out 2007fxdc's bike, I believe he's got the 8"s with the integrated risers. They look really good and should be comfortable for your size. Your stock cables will work fine.
I have the 7" HD bar on my Street Bob and had 4" risers on my '95 Superglide. Both work(ed) fine. When you go with the 4" you need a wide bar to avoid that the signals will hit the tank.
Have a look at my albums to see the two bikes.
These are 8" rise. I didn't care for the stock cable length, so I went 2 inches shorter when I did the chrome controls, grips, cables, etc... With Jackyl's 3" tank lift, it works perfectly. Close, but perfect. As you can see, I moved my signals from the bars. Zero room for them on the bars...
I run Wild-1 model 507 drags. 10" rise with 12" pull-back. You get that drag bar look without leaning too far forward. Standard cables worked. I changed the brake cable though because of the banjo bolt orientation.
