Battery tender pigtail...where do you put it?
I have the HD Battery tender (made by Deltran which you can get on Amazon for $28) that comes with the plug in pigtail that stays on the bike. I just stick it under the battery box cover and remove the cover when I want to charge the battery...(storing more than 2 weeks). So do you guys leave the plug hanging out or have any creative ideas for mounting it so I don't have to remove the cover?
Run wires directly to the battery (use Loc-Tite). To make a quick connect / disconnect you can solder wires to a banana jack and mount it some were out of sight. Use an additional banana jack on the Battery Tender leads.
FRYS.com #: 2379099: http://www.frys.com/product/2379099
Pomona MDP-02 Double Banana Plugs w/ wire Guide. Set Screw Secure Leads, 5000-V DC, 15-A
$4.99
- Set screws secure wire
- Accepts cables up to .215" max.
- Contains one black and one red dual banana plug
- Rating 5000V, 15 Amps
$4.99
Does this qualify? Since this photo was taken, I've painted the electrical cover with the HD Wrinkle Black out of a rattle can. Unobtrusive unless you are looking for it, gives me a connection for charging the bike, and I use it to run my heated vest. I've also had the guys at Powerlet make me a 2 prong SAE to mini usb cable, with a built in step down to 5 amp service. Gives me the ability to charge my cell phone, or bluetooth dongles while stopped.
1 Post
I did something similiar but it's on the battery side still. When I pull my bike in the garage the plug is on the side where the tender sits.
