Fatbob wider rear tire. ????
Old 05-07-2009, 01:02 PM
FatBobBerry's Avatar
FatBobBerry
FatBobBerry is offline
Default Fatbob wider rear tire. ????
I have an 09 fatbob with the stock 180 mm tire and wanted to know what is the widest tire that will fit beneath the stock rear fender. Also has anyone changed the swingarm and fender to accommidate a wider tire like a 230 mm? Suggstions and pics appreciated.
Old 05-07-2009, 01:13 PM
maddghost's Avatar
maddghost
maddghost is offline
if you look ay yhe space between your drive belt and the actual tire there is only about a hlf inch. that leaves 10 mm on either side. If you take a bump or tight turn at speed there is already a chance the belt will rub against the tire. Your safst bet if you want to do that ,i think, you will need a kit,new swing arm fender mods and so on. just my couple cents.
Old 05-07-2009, 02:29 PM
FlatDF's Avatar
FlatDF
FlatDF is offline
Guys here have done 200mm rears on stock setups, which seems to be the max. More than that and you're talking swingarm, fender, wheel, and spacers. I'd be interested to see one rolling on a 240 though!
Chris
Old 05-08-2009, 04:10 AM
Mixter's Avatar
Mixter
Mixter is offline
Ya 200 is the limit I've seen. Otherwise turning is a pain in the @&$
Old 05-08-2009, 12:48 PM
guff's Avatar
guff
guff is offline
Here are a couple pics of a Fat Bob with a 240 tire. I believe the bike was built by a company in Europe but I can't for the life of me find the site now!
Attached Thumbnails Fatbob wider rear tire. ????-fatbob_240_01.jpg   Fatbob wider rear tire. ????-fatbob_240_02.jpg
Old 05-08-2009, 01:17 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Had you ran through the list of threads on page 1 before posting this one, you would have found this thread, https://www.hdforums.com/forum/dyna-...on-fatbob.html. It's approx 10 posts below yours.
Old 05-09-2009, 08:49 AM
FatBobBerry
Thanks for the info guys. I am going to look into the 240 mm that Guff put up. That bike is sick.
Old 05-09-2009, 09:01 AM
AFONE's Avatar
AFONE
AFONE is offline
wide tires are going way of the bell bottom....
Old 05-09-2009, 09:55 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
What kind of riding you like to do?
Old 05-11-2009, 09:47 AM
FatBobBerry
If wide tires are like bell bottoms than the 1960's are back. Just about every manuafacture is doing some type of bike with a wide rear tire now. The Yamaha Raider, Suzuki M109R for examples. Also i like to to take longer rides, not much on city rides or around town. Like the unique looks of that Fatbob with the 240 mm tire.
Quick Reply: Fatbob wider rear tire. ????
