Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#7841
Damn turd nice bike bro. I'm with vdop, let's hear more about it. Looks like stocks heads and cylinders but it also looks like you've been into it, along with everything else haha. What head pipe is that? I like the timing cover too
#7843
Could someone please give me the low down and point me in the right direction, concerning the switch from wire wheels to cast/mags ?
If I understand it so far, My calibers will work, but I will need new Brake rotors?
I need a 17 rear, and 19 front, so I can use my existing tires from my 2014 street bob. What about axle size, spacers Etc.
I am ready to purchase, just not sure what will and will not fit.
Thanks Kindly !
Thanks Kindly !
#7844
[QUOTE=GoneN6T;14067579]Could someone please give me the low down and point me in the right direction, concerning the switch from wire wheels to cast/mags ?
Thanks Kindly !
I believe the rear rotor is the same,but the front is definitely different. If you get new mags the axle size should be the same. I'm sure someone else will be able to tell you about the spacers.
Thanks Kindly !
#7845
Thanks Kindly !
Thanks Kindly !
#7847
[QUOTE=Ironcleveland;14067639]
Do it right, get some 2014/2015 FXDL (Low Rider) mag wheels. Everything on the rear of your bike will work, rotor, spacers, tire, etc.
The front you is dual disc. You will need two lug drive brake rotors and rotor bolts. Your spacers, tire etc. will work.
But at some point you will need to convert to dual disc right side fork leg. You will need a right side caliper, brake lines. You will have a dual disc brake bike.
If not source some 2007-2013 style FXD mag wheels and one lug drive brake rotor and rotor bolts. Or you could buy some of HD's accessory wheels, or aftermarket.
If you really have the $$ get some San Diego Customs wheels. They are really cool wheels.
Thanks Kindly !
Thanks Kindly !
#7848
[QUOTE=Lama;14067698]
Are you talking about the Low rider "chunky" mag wheels ? if so, I do not see them on the HD website...any idea where to see and price?
Thank you.
Thank you.
