***Dyna Models Wiring Diagram Links Index*** part 1
Old 06-26-2013, 03:13 PM
**Blu**'s Avatar
**Blu**
**Blu** is offline
Default 2012 Wide Glide
Same here as Gummi, I am looking for the wiring diagram for rear turn signals on a 2012 WG. No center light, two side pucks handle running, brake, and turn. Aftermarket center light was added but that was a quick plug-in via HD. I am asking 'cause I am looking to get black rears, but am trying to figure out if I need a 2 or 3 wire setup.
Also, because I am probably gonna go with the LED's, I was told I will need a 1-100 ohm resistor... How does this fit in...?
Thanks in advance.
  #92
Old 06-27-2013, 01:48 AM
ZeroThoughts's Avatar
ZeroThoughts
ZeroThoughts is offline
Thanks in advance.
Check the wire connector carefully. There should be 4 wires if your set up is 'Running/Brake/Turn', 1 wire per function & 1 Ground. If you have 3 wire set up then it will most probably be a 2 function set up 'Run/Turn' or 'Brake/Turn'.
  #93
Old 06-27-2013, 04:25 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Thanks in advance.
2012 FXDWG rear lighting without center stop lamp:
  #94
Old 06-27-2013, 04:30 AM
FXD2003Rider
Originally Posted by gummi
Hi,
Does anyone know where to find a wiring diagram for a Dyna WG 2011?
My model doesn´t have a tail lamp, it´s built into the turn signals.
I´m going to install a new tail lamp and nead to sort out the wiring to the tail lamp. At the moment there are only 3 wires to the turn signals.
Black - Ground
Blue - Constant running light?
Purple/brown (or similar) - Which seems to be both turn signal and brake signal in the same wire.
I also need to know wiring to the front turn signals, I´m going to disconnect the constant running light and need to find out where to cut those wires.
All help is much appreciated!
/Martin
I do not have access to 2011 wiring diagram info. The image in my previous post (2012 wiring info) might help?
Front running lights have a blue wire.
  #95
Old 06-30-2013, 01:28 AM
**Blu**'s Avatar
**Blu**
**Blu** is offline
You sir, are the "Miracle Man"! So it looks like I know which ones to order then. But can anyone explain how I would tie in the resistor? I gonna have to cut, splice, and sauder some wires aren't I?
  #96
Old 10-29-2013, 08:09 AM
mudrat_fat05's Avatar
mudrat_fat05
mudrat_fat05 is offline
Default 1998 Dyna Wiring Diagram
I have been searching the forums for this and had such a hard time, I looked elsewhere.
Since I picked up a 97 FXDWG i have been trying to repair the lighting that someone had hacked to the point of it not working. But being here in the great state of Florida, we all know how important it is to be seen.
No front signals, only head light
No rear, only stop light.
Thru trial and error I was able to get the rear tail light working but no directionals.
I found on the JP Cycles support page the attached diagram for 1998 Dyna Glide models.
I will be going outside today to verify if it is the same for a 97 model.
Cheers,
Ray
Attached Thumbnails ***Dyna Models Wiring Diagram Links Index*** part 1-1998-dyna-wiring-diagram-copy.jpg
  #97
Old 12-28-2013, 02:30 PM
Yankeedave's Avatar
Yankeedave
Yankeedave is offline
6th Gear
2011 dyna diagrams
Attached Thumbnails ***Dyna Models Wiring Diagram Links Index*** part 1-image.jpg
  #98
Old 12-28-2013, 02:40 PM
Yankeedave's Avatar
Yankeedave
6th Gear
Sry tried to post as a image but it will not let me so here is the attachment. I'm about to install 2x kellermann 3 in 1 934705
Will I need to add anything inline like resistors?
  #99
Old 05-09-2014, 02:56 PM
FXD2003Rider
  #100
Old 05-19-2014, 10:01 PM
hdflash1's Avatar
hdflash1
hdflash1 is offline
Stage II
Default Wire Diagrams
I have the following wiring schematics if interested and you have somewhere to send them:
1978.5-1979_FX-FXE Wiring diagram
2001 Touring wiring diagrams
2002 Touring wiring diagrams
2006 Touring wiring diagrams
2010 Touring wiring diagrams
They are all PDF files and zipped in a 3.3 MB zip file.
Quick Reply: ***Dyna Models Wiring Diagram Links Index*** part 1
