CAM Sensor Cover
CAM Sensor Cover
I'm probably missing this in the service manual, but my wife picked up a new CAM Sensor Cover for my FXDF. I've looked in the manual and can fine torque settings for the CAM Cover, but can't find anything for the bolts attaching the Sensor Cover to the CAM Cover. Don't want to over or under torque it.
Received 4,312 Likes
The term Cam sensor cover is a carry over from the older engines. If you have fwd controls the cam cover is next to your right heel, and the little round cover with the five screws is called an ignition cover, again an old carry over name. There are no ignition parts behind this cover. There is a tighening sequence to the bolts and the torque is 90-120 in. lbs.
http://www.nightrider.com/biketech/hdtorquevalues.htm
