Problem stalling after rain
Hi guys,
It rained pretty hard today, and all if a sudden, the bike started acting really weird.
First it popped, then it stalled, and then it wouldn't start again easily, ie I had to give it gas to get it work, and in order to get home, I had to stay on the throttle all the time or it would stall.
The things I think might be causing it, since it only happened after the rain,
1 could be that since I don't have an air filter cover some water got sucked in,
2 I installed flush mounted gas cap and indicator
Or something completely diffent
I'll see how she reacts tomorrow morningmand probably stop at the dealer on the way to work.
Anyone experience something similar?
Thanks
Lou
Thanks
Lou
I ask this knowing that it is usual to suspect an electrical problem in the rain.
Same thing happened to me after a wash. HAd water get in the connection between the PCV and the stock ECU. Took it apart, dried it out and sprayed some wire dyrer then all was good.
So it was the PCV...opened it and a waterfall came out.
I have taken it off, and now the bike is running very well.
Thanks for the info guys, it was you that fixed my bike, not the dealer...they didn't know what the problem was until I told them what I'd read here on this forum...
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
Thanks again,
Ride Safe,
Lou
