06 dyna inner primary bearing failure: Please read!!!
Old 08-18-2010, 01:55 PM
Crusty369's Avatar
Crusty369
Crusty369 is offline
Exclamation 06 dyna inner primary bearing failure: Please read!!!
:haThe MoCo apparently has finally gotten their collective heads out of their ***, and have come up with a fix as opposed to a band-aid for the inner-primary bearing wear issue. Inner case replacement, stator replacement, shaft, bearing, etc. Should be gratis, but perhaps a slight deductible involved without extended warranty. ppybd:
UPDATE#####Totally FREE. Even waived the deductible.
I'll get a copy of my WO scanned in here ASAP, for those of you that need it to steer your dealer into doing the right thing.
Shawn
DON'T TAKE NO FOR AN ANSWER!!!!!!!!!! This is a safety issue!!!! That was my approach when I contacted Harley In Wisconsin. They had funds allocated for this repair every 5k miles, for every 06 Dyna owner who experienced this IPB problem. The service bulletin miraculously disappeared. Read through the WO, and you see it is a major mechanical repair, directly related to mismanufactured parts. Same type scenario as the Toyota debacle.
Good Luck!
Attached Thumbnails 06 dyna inner primary bearing failure: Please read!!!-scan0009.jpg   06 dyna inner primary bearing failure: Please read!!!-scan0010.jpg   06 dyna inner primary bearing failure: Please read!!!-scan0011.jpg   06 dyna inner primary bearing failure: Please read!!!-scan0012.jpg
PaulG75 (04-15-2021)
Old 08-18-2010, 02:58 PM
HoolyNI's Avatar
HoolyNI
HoolyNI is offline
Have an 06 fxdci with 12k on the clock. What symptoms would I be getting if there was a problem?
Have noticed a noise on the clutch lately when dropping from 6th to 5th almost as if i'm letting the clutch out too quick, but other than that she runs pretty smoothly.
Old 08-18-2010, 03:33 PM
Mascman's Avatar
Mascman
Mascman is offline
That is really good news. Bought time they step up to the plate.
I had trouble getting the dealer I bought mine from to replace the injectors when out of warranty...ended up doing it myself.
I've got over 10K on my '06 and this is always on my mind...will keep this info handy.
Old 08-19-2010, 01:23 PM
smitty544's Avatar
smitty544
smitty544 is offline
thanks for the info crusty. my 06 WGI is in salt lake at the dealership waiting for me to pick up. the alternator- stator went bad, got it to the shop and watched the mech take it apart torx screws came out and took out the stator and the primary bearing. bike has just under 15k. i made copies of your work order, mayce it will do me some good. the bill for the job plus 15k service is 950.00 could use some help on this one. thanks again.
Old 08-19-2010, 01:31 PM
QehQeh's Avatar
QehQeh
QehQeh is offline
Do thorough research on this forum regarding the rotor/stator issue and the IPB issue (separate issues). The MOCO will repair both of these problems for free, IF you do your homework and follow the proper protocol in dealing with HD customer service and your dealer.
Old 08-19-2010, 07:23 PM
ehc0720's Avatar
ehc0720
ehc0720 is offline
Thanks, I have an 06 at this is always in the back of my mind, no issues yet though. How can I get your work orders large enough to be able to read them?
Old 08-19-2010, 08:00 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Old 08-19-2010, 09:49 PM
Wonkaboy's Avatar
Wonkaboy
Wonkaboy is offline
When i first got my bike i had heard about this IPB problem but i had no problems with mine ( YET ) i also received a letter from the MOCO stating mine was not part of the VIN # batch , well at 5,000 it went anyway and the dealer repaired it for free my personal friend had worked there at the time and repaired it himself he said a pitted bearing was the problem , now i have 15,250 and it's still fine , according to another post i'm supposed to bring it in every 15,000 miles i guess i'm going to call the MOCO first and get a reference # before i bring it to the dealer , I would hate to break down somewhere because of my negligence not to follow up on this issue , What is the correct phone # to contact the MOCO on this issue ?
https://www.hdforums.com/forum/dyna-...-bulletin.html
Old 08-19-2010, 10:01 PM
Stomper-63's Avatar
Stomper-63
Stomper-63 is offline
Does this factory recall/warranty only apply to original owners or for the life of the bike regardless or ownership transfers?
Old 08-19-2010, 10:28 PM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I was 3rd owner of my '06 Wide, and both my IPB failures were covered by HD. Search for my thread "Finally Good News..." for prit-near all you'd need to know about the IPB issue.
Quick Reply: 06 dyna inner primary bearing failure: Please read!!!
