Reflectors and safety inspections in VA
Not sure about rest of world, but there is a DOT regulation stating that the reflectors have to be on the motorcycle. I don't see anything in my searches on Virginia safety inspections that require them.
Anyone had any issues with passing a safety inspection in Virginia without side reflectors?
No idea about passing inspection in Virgina, but here in NY it's pretty much a non-issue.
It sounds like you're asking because you want to pull the reflectors off. If that's the case, I suppose you could remove them, and if need be, tack them back on temporarily with some two sided tape for inspection purposes, then take them off again once you pass.
My major concern is when the little old lady hits me broadside stating she did not see me. Her insurance company is not going to cover my hospital bills or repair the damage done to the motorcycle because I removed the safety reflectors. Just my .2
Yamaha is having to recall more than 50,000 2010 Yamaha YZF-R6 motorcycles: The front reflector on the base of each fork leg is in the wrong position, according to government standards.
The National Highway Traffic Safety Association announced the recall of the motorcycles, produced from August 2005 to March 2010. The reports states that the “motorcycle’s front side reflector was not placed at the proper height which fails to comply with the requirements of federal motor vehicle safety standard No. 108: Lamps, reflective devices, and associated equipment.”
Because the reflector is not in the correct position, the NHTSA asserts that the motorcycles are less visible. The mistake could increase the possibility of collisions. Yamaha knows that the incorrect positioning of the reflectors could expose them to liability in certain crashes where a correctly positioned reflector could have provided more warning and the potential to avoid the collision.
< 571.107 571.109 >
Subpart B—Motor Carrier Vehicle Safety Standards
§571.108 Standard No. 108; Lamps, reflective devices, and associated equipment.
S1. Scope. This standard specifies requirements for original and replacement lamps, reflective devices, and associated equipment.
S2.Purpose. The purpose of this standard is to reduce traffic accidents and deaths and injuries resulting from traffic accidents, by providing adequate illumination of the roadway, and by enhancing the conspicuity of motor vehicles on the public roads so that their presence is perceived and their signals understood, both in daylight and in darkness or other conditions of reduced visibility.
S3. Application. This standard applies to:
(a) Passenger cars, multipurpose passenger vehicles, trucks, buses, trailers (except pole trailers and trailer converter dollies), and motorcycles;
(b) Retroreflective sheeting and reflex reflectors manufactured to conform to S5.7 of this standard; and
(c) Lamps, reflective devices, and associated equipment for replacement of like equipment on vehicles to which this standard applies.
< 571.107 571.109 >
I would also be more worried about parking my bike at night, I feel like reflectors wouldn't really help me while I'm actually riding it. When you roll down a street with no streetlights, usually one of the most obvious things you see are all of the car and bike reflectors shining your beam back at you.
